1. Dismiss Notice
    Dismiss Notice
Ignition Switch overhaul
Discussion in 'The Garage' started by peanut, Jul 22, 2016.
  1. peanut
    peanut XS650 enthusiast & inveterate tinkerer Top Contributor
    4,054
    2,700
    263
    England
    Thought the following images of the insides of my ignition switch might be helpful to anyone else thinking about replacing or overhauling a faulty switch. Its very straightforward .There are only 6x screws in the whole switch as most of it simply slots together.
    Ignition switch removed from XS650 1979 special ll
    Unscrew and seperate the switch body from the base. Lots of oil in an unsucessful attempt to get the switch working
    Pull the nylon steering lock cam off the switch shaft. Spiders nest has come all the way over the pond from Iowa!
    The circular wired disk just lifts out. Note the locating slots
    gggGary likes this.
  2. peanut
    4,054
    2,700
    263
    England
    Flip the disk over to inspect the copper contacts. No wonder there was a voltage drop and intermittent operation. These will need a good clean !
    Pull the switch contacts off the shaft and and the switch position plate lifts out.
    Carefully undo the 2x screws and remove the switch shaft and limit plate
    Seperate the switch shaft from the limit plate
    gggGary likes this.
  3. peanut
    4,054
    2,700
    263
    England
    Undo the two lock screws and dismantle the steering lock mechanism
    Thoroughly clean all parts. Apply plenty of white grease and reassemble
    Reassemble the switch shaft and contact plate Apply grease to all moving parts aoiding the electrical contacts
    Ensure that all the electrical contacts are clean before replacing the contact disk
    gggGary and Paul Sutton like this.
  4. peanut
    4,054
    2,700
    263
    England
    Replace the nylon cam in the steering lock mechanism . Screw the two parts of the switch together .
    All that remains is to check the switch operation with a multimeter before replacing in the bike.
    The switch now has a positive click at every key position just as it would have when new and there is now no voltage drop through the switch
  5. TwoManyXS1Bs
    gggGary likes this.
  6. peanut
    4,054
    2,700
    263
    England
    How I wish i had some of that :D
    I guess if the white lithium grease lasts another 36 years its gonna see me out
    gggGary likes this.
  7. Bob Kelly III
    Bob Kelly III Ranch Kid from way back,.... that got Old !
    Hay Peanut !
    I know this is an old thread But....... I am doing a switch overhaul because the fork lock doesn't work !
    so I took it apart and it is exactly like yours My problem is Understanding how it is SUPPOSED TO WORK !
    I think to get the forks locked you are supposed to Push in on the key-switch in the off position and turn the key.... BUT my key does not turn either way
    when pushed in..... (is it supposed to ?)
    Perhaps it is just turning the key to the left past the off position that is supposed to extend the pin.... but I don't know
    I thought you had to push in on the key and turn the key to engage the locking pin but I do NOT know....
    could you or anyone else shed some light on this for me Please ?
    thank you very Much !
    Bob.........
  8. Bob Kelly III
    oh and Peanut you forgot the spring inside the switch that pushes on the contacts ! and indents ....<grin>
    .....( well My switch has a spring in there anyway !) ( which I left out and it seams to work fine now!)
    Bob......
  9. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    bob on the later specials; key to left til it stops ie the normal off position, push in, release ie let key come back up, now it will turn left to engage the fork lock. yeah it's a bit arcane, took me a bit to figure out also. 'specially cause I didn't RTFM.
  10. Bob Kelly III
    Thanks Gary ! I actually figured that out as it was the only way it would go together and have some semblance of working ! LOL
    with everything lubed up good it's working but a bit stiff ...I suppose it should be ! LOL
    I left that spring out as it made it very difficult getting the contraption back together as it was one of the screws that hold the fork lock portion on
    stripped out anyway... so I jerry rigged it and got it to hold
    now to put it back together again and Now I can lock the forks !!!!!!
    all in all I guess Clean livin' and perseverance prevailed ! HAHAHAHHA!
    the inside of that key switch is a myriad of channels and notches and it will go together about 3 different ways, but Only ONE way will everything work like it should ! LOL ... I even had the tumblers out ! ( had to put my glasses on for that ! )
    i figured the contacts were dirty and needed cleaning anyway and they really were cruddy ! bound to help transfer power better now !
    thanks Gary ! Much appreciated !
    Bob..........
  11. peanut
    4,054
    2,700
    263
    England
    I didn't forget the spring Bob , you can see it in image #3 . I didn't remove mine because ,like your switch, it wasn't the issue.
    I wouldn't recommend removal of the spring because it is there for a purpose ... It is a struggle to get the thing back together , you need 3 hands but it can be done with patience.:)
    gggGary likes this.
  12. Bob Kelly III
    Hi Peanut ! THANK YOU for the thread here ! Good show it's just what I needed !
    yes I discovered that that Ornery spring is what pushes back on the tumbler when you push down ... release and then turn it left !
    I don't think mine was broke I just didn't know how to operate the dumb thing ! Garys explanation confirmed that ! LOL
    But seriously thank you for your hard work on making this thread !
    Bob.......
    peanut likes this.
  13. Bob Kelly III
    and Yes I did see the spring after looking through the pictures 3 times and then i finally saw it on the shaft down deep....
    KOOOL ! so I had it assembled all wrong that spring goes under the stop plate that will push the tumblers back up !
    so I'll go tear it apart and put the spring back in there right !
    Thanks Peanut ! your a life saver !!!!!!!
    Bob...........
    gggGary and peanut like this.
  14. peanut
    4,054
    2,700
    263
    England
    thanks Bob its always nice to get a bit of positive feedback :)
    You need to be a smart octupus to put that switch back together again.
    gggGary likes this.
  15. gggGary
    What? done several it's not THAT bad. Anyone with three hands will have no problem. Man up Bob, do it right.
    robinc likes this.
  16. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,398
    3,498
    313
    U.S.A.
    I've done one three times, so not that bad ;) I think I remember something about leaving the key inserted to keep the tumblers in place when removing the cylinder or something...
    Voltage to the coil goes directly through this switch so it needs to be very clean if you expect a good spark. For a nominal 12 volts, if the coil is only about 2-3 ohms then just 2-3 ohms resistance from key switch crud would voltage divide you to just 6 volts at the coil...
    gggGary likes this.
  17. Bob Kelly III
    gggGary ! I did I put the spring in there and put it all back together No problem it went together much easier with the SPRING in the right place
    LOL
    and now the push in of the key has a return like it should..... I guess they have a ball-point pen push to click on and push to click off type of system in there.... it's an ingenious over engineered piece but I can't help but wonder WHY...... HAHAHAHA!
    XJWMX : sounds like a real good reason to keep those contacts clean in there.... and YES leave the key in there ! LOL
    Bob........
    gggGary likes this.
  18. Dave79sx650
    Dave79sx650 XS650 Member
    Do I even need a kill switch if I have a key switch ???y do u need both
  19. peanut
    4,054
    2,700
    263
    England
    Welcome Dave
    no you don't in fact they can be a nuisance at times, I always use the ignition switch . I've lost count of the number of times I've accidentally knocked the kill switch to off and struggled to start my bike until I think of checking the kill switch.
    gggGary, YamadudeXS650C and robinc like this.
  20. gggGary
    Need is a strong word but handy as all get out now and then sure fits. Most of the ignitions get rather unhappy being left on with the engine not turning. Not rare to want a light on or check something electric without motor running. An XS never has a "shift to neutral when stopped issue"......
Share This Page
