hi, new member . i' have been reading here for 4 months now, and i have learned and fixed a few problems . thank you all for sharing. i have an 83 stock that i unplugged the reserve lighting and self canceling relay. i have 2 questions, i need advice with. with engine running... i turned the ignition key to off , it still ran until i turned the kill switch off. is this normal? the other question is .. when mounting the chrysler reg and radio shack rect to the battery tray , i'm to ground the regulator and therefor the tray. is this safe for the relays? like starter, headlight and safety relay? by the way..i haven't connected the gauges or signals. Headlight and horn is not getting juice, if that makes a difference.. . i got this bike 4 months ago from seating for 8 years. i cleaned carbs, rebuild forks, flushed the motor and it runs pretty good on new battery. either rotor or stator is not working ,but that's another story. can someone help?
