rich_mcd
I have a 1980 xs special with stock TCI ignition, charging system, reg/rect. I have open 1-1/2" pipes with washers in them. Rejetted pilot and mains. Plugs are in decent shape (maybe a little lean if anything) Carbs were stripped and cleaned in the spring. I have had some intermittent issues with my bike firing on one cylinder, not turning over, and just all around not running well. It ran well for the majority of the season and once fall hit it just began to run worse and worse. I have been running fuel stabilizer throughout the season and use premium/low ethanol fuel.
I had planned on replacing the ignition system and adding in hugh's PMA when needed. I think the upgrades might be needed now. I was thinking that I would start with just upgrading the coil for now and see how it runs. If the problems don't resolve I was going to add the Pamco with E-advance or the boyer ignition found on Lowbrow http://www.lowbrowcustoms.com/p2595/buy/m-c-parts/electrical-amp-wiring/metric/ignition/boyer-bransden-electronic-micro-digital-ignition-system-for-yamaha-xs650s-kit-00103/ I am trying to avoid using points and keeping the electric.
I am trying to avoid buying a coil from Mikes, so the options I have been looking into are the Honda MP08 (used) Andrews 2.8 OHM dual fire, ACCEL HEI super coil 2.3 OHMS or the Drag Specialities 3 OHM dual fire coil.
The big concern I have is compatibility between the coils I mentioned and the upgraded ignitions (ie - boyer or pamco) and the PMA. I am currently running a Ballistic battery and never use the electric start.
The other question I had was regarding the andrews/drag specialities coils and attaching the plug wires. Do they screw onto the threaded studs on the end? Is there a cap that goes along with it like some of the coils from Mikes?
Sorry for the long winded post.
Thanks guys
Thanks guys
