AaronOregon
1980 XS650 Special with BS34's and the last era of the brass floats. Right side is backfiring upon revving and not getting very hot. It idles like it's firing on 1 cylinder and than when you rev it up it fires on it, but also backfires. I have pulled the carbs and cleaned them 3 times, installed a complete carb kit along w/ new floats, adjusted valves, timing, swapped and reversed plugs and plug wires to eliminate coil issues. It stays on that side. Where else do I go? Getting very frustrated. Thanks in advance guys!
Aaron
Aaron
