section8joe
I'm extremely new to wiring but everything is working and charging. I'm cleaning up my wiring and I wonder if I can switch something up. Right now I have my ignition switch the from the switch my red wires split. One wire is fused and goes to my battery. The other wire goes to the reg/rect. Here is a little picture of how I'm currently set up.
Now, I have my rect/reg mounted to the outside of my battery box. I would like to just run a wire from the rect/reg straight to the battery. If I did this I would have my ignition switch going to a fuse then down to the battery and right before the battery my rect/reg would be spliced in. Here's a pic.
My current set up has two red wires running from my ingition switch(on my oilbag) all the way down to the battery and the reg/rect. If the other setup works then I will have one less wire to run through my frame.
What do you guys think?
