Shifty2932
So recently as far back as 3-4 weeks ago I have been starting to have problems with riding my bike on the interstate (cruising about 65-70, thats a guess as I don't ride with a speedo or tach). But every now and again I get on the interstate to go to work and the bike starts to stall out around 5 min of high speed riding. I am still in the process of trying to tune my carbs. I have 1977 xs650 w/ UNI 4" Pods, straight pipes, and BS38's. As of Sunday the carbs are now setup as follows. Pilot - 35, main - 142.5, needle clip is in the second slot, and mixture screw is 2.75 turns out. Before Sunday the only thing that was different was the pilot jet was a 32.5. But in this setup I was hitting a flat spot around 1/8 throttle and getting lots of break up. And still in that setup I was having intermittent issues on the interstate. And before that setup I was running 30 pilot 142.5 main and needle clip in the 3 slot, but again still intermittent issue on the highway and this setup was just sluggish all around and that is why have leaned the needle and increased my pilot to what it is now. The current setup seems to work really well. Much better throttle response when the bike is wanting to run. Now when this happens I pull over let the bike sit for a bit and start it back up and allow it to idle. Bike will run okay for a little bit 10 min and start to stall out again. It will sit all day work and I ride it home with little to no issues. Any thoughts? There has also been a few times were gas wants to piss out the left air pod (this morning, as it died a few miles done the road from my house house), but this as only happened a few times. I orginally replaced the left float needle, maybe I need to replace the right one has well. The floats are set at 24mm and this seemed to have worked really well for me as before they were set at 22mm and I was running really lean. I intend to rebuild the carbs this fall. I have checked the voltage of the battery before and the volts climb as R's increase.I feel like I am just banging my head against the wall. and i want to be doing more of this - .
