funky
XS650 Junkie
Hi All hope you are well.
I rebuilt my top end and re jetted my BS34s to stock jetting.
The book says for my year and and carbs that the mixture screw should be 3 1/2 turns out .
I started to get my jetting done based on what the plugs are indicating bearing in mind I do not want to run the bike lean , that why i returned to stock jetting.
My issue is with the pilot circuit I have a 85 air pilot and went to a 37.5 Pilot jet ..... Stock should be 47.5 pilot jet Plugs were black so i started on the the mixture screws to lean off the mix. 3 1/2 turns out is far to much no matter what jet i use.
I slow the engine down once nice and warm, screw to mixture screw in to weaken the mix looking for a slight increase in RPM (The Sweet Spot ) and the same thing happens. The sweet spot is always about 1/4 turn out from bottoming out on either carb. I have gone from a 47.5 to a 30 pilot jets same outcome.
Now as far as i am aware my float levels are perfect 21 mm to 22 mm checked and double checked. no air leaks checked. diaphrams are ok also .Carbs are balanced
main jet is a 140 as when it was stock the engine ran like shit more than quater throttle.
needle jets set on number three notch . as per manual. im stupped
Remember every things good after quater throttle its just when idleing. Any ideas I am sick of pulling those carbs apart.
All the best Funky
All the best Funky
