Gmorrone1214
Hey guys I been searching this forum in search on a answer. My 1979 xs650 is being a tad rough to me in the kickstart department. I just cleaned the carbs and replaced a few parts and resynched the butterfly valves. It idles great, rev sticking but just found out advance springs are shot. Also have pod filters and straight back exhaust..idk if it matters also stock carb parts. anyway...
Sometimes when kickstarting it tends to kickbac. I adjusted the timing and it is spot on, used a timing light. Also check the advance timing and also good. Sometimes the bike likes to start of 1-2 kick, other times it takes like 20 times lol. Not sure what the problem could be of the kick back and also not starting up.
I also checked for air leaks on the manifold boots and got nothing, used carb and starter fluid both no change in the rpm.
