LeisureMaster
Hey guys, I've been following this page for some time now and without fail has helped me every time!
I have a bit of an issue..
I have a 1974 TX650a, I recently pulled the top end apart due to a crack under the cam shaft which resulted in a litres of oil pissing out all over me on a hot day driving down the highway. Wooohoo.
Everything is back together and my timing is reletively correct, today the bike started second kick. ran for about 2 minutes then ran out of fuel due to me feeding it externally without the tank.
Went to kickstart it again and now the kicker is not engaging but rather letting me kick it down without resistance and then returns back to its normal position.
I can hear the compression sucking from the carbs and blowing out the exhaust so I don't think its a compression issue. I have completely loosened the clutch and and the worm gear screw so that can't be the issue.
Im all out of ideas, hopefully someone can help!
Thanks.
Thanks.
