gray am I
Put my clutch cover back on after doing the #4 spring clip fix and replacing my clutch basket and I found the kickstarter travels almost all the way to the bottom and only engages a very small amount at the very bottom. I am able to use the electric start now and it seems to be working fine in starting the engine, and once started I can get it to kick over using the last 2 inches of kickstarter stroke.
I remember when I was removing the clutch cover the kickstarter shaft coming out about 5-10mm, and I am wondering if there may be a problem with the spring?
