I have an unusual knock in the engine when gently rolling on the throttle. It only happens when starting from a dead stop or when cruising at a constant slow speed and then gently rolling the throttle on. I've adjusted the valves, cam chain tensioner, checked the timing advance rod, all of which seem fine. It sounds very much like a rod knocking (which I've heard several times before, I used to race cars), but I've never had a rod knock that went away under hard throttle. Also, there are no other symptoms, the engine runs well, and there are no unusual vibrations. I'm a little confused by it, so I thought I would put it out there and see if anyone had experienced this with their XS. I'd like to avoid teardown if I can, but don't want a hole in the case where a rod exited either.
Thanks in advance,
DLD1
Thanks in advance,
DLD1
