PetesPonies
anyone laced a drum brake hub into a '75 type aluminum wheel before? If so, what drum/hub assembly and what spokes etc. Thanks
- the original drum front XS1 had 19in chrome rims, the SR500-18in...when swapping rims the problem is the angle the rim spoke holes are bored, if theyre not bored to the same angle as the spoke approach, the spoke head doesnt sit evenly in the dome and you get pressure points...rims start to crack at the spoke holes and spokes start to break-especially the more brittle stainless ones...for some this isnt such an issue but i ride a lot in the mountains etc so braking and cornering stresses are high
- another drum that commonly gets used is from a GT750 4LS waterbucket suzuki...take about 9mm off each side and rebore the fork for the non clamping end
