Spoke offset for a 78 special.
staf0s
Ventura County, CA
I purchased some complete wheels from a guy on eBay. They were on a 1978 xs650 special. Like a fool I didn’t do any research and took them apart to get the hubs/drum polished. I called a local guy to true and lace for me and he wanted to know what the offset was for the spokes on both wheels.
Just got my hubs polished and purchased new stainless spokes. My fault for not researching this prior. Calling a few people to get my wheels laced and true’d. They all want to know the offset of the spokes. I have no clue and I’ve read mixed answers online.
1978 XS650 Special
Factory Takasago 19x1.85 and 16x2.75
36 spoke front and rear
rear drum
I can’t find much tbh. Any help is appreciated
Hmm...I've seen this reference to "offset" mentioned before. IME, once the spokes are made, the offset is pre-determined. Also, I'm unaware of a '78 SE having spoke wheels - maybe a '79 - '81 Special II :shrug:.
I'm guessing the 16" could be a 36-hole and likely laced in a "cross one" pattern and the 19" a 36-hole laced "cross two"
See Tech section for model ID
Yeah im really not sure. The listing said 78 special. I reached out to the seller.
Here are some close ups of before I took them apart
If you don't want to lace the wheels yourself, take the swinging arm into the lacer and he can lace the wheel with the correct off set according to the swingarm.
Alternatively if you have the correct spokes, just get the lacer to lace the wheel so the thread on each spoke just disappears inside the nipple, that'll get it pretty darn close, if not perfect, then you can mount the wheel on the bike and finish with any minor adjustments to get the rim in the centre of the swingarm.
There isn't anything in the Tech menu on lacing wheel. A couple of threads. Need to read through them all and gleem the info for respoking. It's all there. Links in the links should be looked at a well
https://www.xs650.com/threads/wheel-lacing-101-it-looks-so-easy.27731/
https://www.xs650.com/threads/how-to-wheel-lacing.52594/
https://www.xs650.com/threads/spokes-do-not-look-right.47200/
This is more for realigning the rim holes
https://www.xs650.com/threads/lacing-mikes-2-5x18-rims-to-stock-hubs-w-ss-spokes.44710/
Steel 36 spoke rims would make the wheels '80 or '81. '79 had alloy rims and '82 saw the introduction of those mega-spoke Heritage wheels.
All you really need to know is that the rim is centered over the spoke flanges. On the front, that would be centered on the hub as well, but not on the rear. On the rear, the sprocket side of the hub sticks out more.
So my understanding of the term "offset" regarding motorcycle wheels is the difference in the centerline of the spoke flanges and the centerline of the rim - that's dictated by spoke lengths. If you have 18 identical inside spokes and 18 identical outside spokes the offset (in this case) is zero. The sprocket or brake mount flanges are what they are.
The rigid frame doesn't require a different offset given a particular hub; it may require different spacers to align the sprockets, etc.
On some other motorcycles the wheel is offset to one side with one set of spokes being straighter the other at more of an angle. Several brit bikes have that offset.
