lil2lo
Hi there,
So I recently bought a 1970 xs650 cafe racer. It has a 1977 engine with 1976 carbs. It has been sitting for a while so I'm doing some minor work on it to get it going.
The carbs where the first things on the list. They were leaking fuel. I cleaned them in a ultrasonic machine, cleaned everything again, checked, etc, etc.
After setting the floats, I put them back together and tested them in a setup on my workbench. With a clear tube from the float bowl I measured the fuel level. The new viton tipped needles are holding the fuel nicely. But now the problem. I measured the fuel level at 8 mm below the lower edge of the carb body. This is to low so I adjusted the floats. Then it was at 3 mm, so I was kinda happy with this, but after a while fuel was starting to leak from the carbs. It appears to come from the top of the float bowl. Both carbs are leaking. It's not much, but any fuel leak is to much in my opinion. With the fuel level at 8 mm the carbs didn't leak.
So how can carbs leak with the fuel level at 3 mm? Do I set them at 8 mm or will this be to low?
