pebiker
Do I raise the clip to lean, or do I lower to lean
agreed.........No, you raise the clip which lowers the needle. When you raise the needle, it lets more fuel in, not air, and makes things richer.
First, you're using the wrong plug, both type and heat range. You should have a BP7ES in there. The "BP" means it's a projected tip type and the #7 is one step hotter than the 8. That cold #8 plug is probably contributing to the fouling.
The 135 main and 27.5 pilot are the stock sizes. They will need to be stepped up one or two sizes on both, maybe even a bit more on the main. The needle in the #2 slot is already leaned a step, leave that be if you increase the other jets. If you don't for a while, put it back in the stock #3 (middle) slot.
Yes, the colder plug will burn darker and give the appearance that you're too rich. The other important setting you must get right on these carbs is the float level. If it's off and the fuel level in the bowl is too high, the bike will run rich regardless of what jet sizes are in there.
