pamcopete
Ride.Enjoy.Life is Simple
good point.
In that situation if you would like to limp the bike home on the battery, it would not be hard to bypass the relay. The relays I use have a mechanical operator right on top. Just lift the plastic lever and it is 'energized' and you would be off running for however long your battery lasts. It still has its flaws but once I get it on paper I'll see if its still worth doing.
Tim,
If I thought this was a real problem, I would just lash a thermal switch with normally closed contacts to the coil and set it to open at 175F and close at 150F. These switches are very common in appliances, like clothes dryers and coffee makers and they are usually less than $5. The coil self destructs when left on with continuous current flowing because it gets too hot, like, 200F +. The thermal switch would cycle off and on about every 15 minutes if the ignition switch and kill switch were left on long enough for the coil to heat up to 175F.
If you are going to design something else, then all you have to do is turn off the current to the PAMCO red wire because when it is off there is no current flow to the coil.
