Long starter bolt needed.
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
I’m sure someone on here went through this. Where can I buy one? Used is fine if one of you have one to spare.
Both mine got trashed removing them on the SG resto.... so this is from about 4-5yrs ago, but new ones were impossible to find. Nobody had 'em.
If you want to expand your search, a 10-32 screw will work. That's what I wound up using, a 10-32 stud from Pratt & Whitney with a nut on the end.
If you want to expand your search, a 10-32 screw will work. That's what I wound up using, a 10/32 stud from Pratt & Whitney with a nut on the end.
Yep. I saw that, and it can certainly do the job. One of the usual suspects has already come through.
I love this place!
I'm seeing the stud but where the arrows point did you re use the head off the old bolt as a flanged spacer (cut of and drilled out)
