Sgilliesjr
I have a rear wheel from a 72 xs650. Other than the rim spokes and hub I had to find sources for all the other wheel parts. I ordered both the right and left bearings, the bearing spacer with the flange, and the top hat. I noticed there is about 1/8 to 1/4 inch space between the bearing spacer and the top hat spacer when assembled. Does this seem right. I thought that the thrust from torqueing the axle would cause the inner race on both bearings, the bearing spacer and top had spacer to make contact with each other when torqued. This isn't going to happen if there is that much space between them, any suggestions. Before anyone asks yes I believe both bearing are fully seated. I am wondering if I purchased the right bearing spacer or top hat spacer.
