sandman 315
XS650 New Member
so everytime i turn my key on i can watch my voltage drop at roughly .01 volts per second consistanly, ive unplugged everything on the harness in search of what was causing the problem, i can pull the main fuse and the voltage will jump up 3 volts instantily, and then climb back up at roughtly the same rate as deceleration. with the main fuse in if i pull the red wire going to the starter selonioid everything will climb back up.any ideas? anyone ran into this problem?
