section8joe
I have an 83 heritage special and I'm looking to add single front brake line instead of the two piece with a junction. My front brake is stock and I'm trying to use this small master cylinder. Does anyone recognize it? I got it from a friend and I'm not sure of the bore size. The banjo bolt thread size is an M8 1.25.
Can you guy tell me what size banjo bolt the front caliper uses? It look a little larger then a m8. I think it may be a m10.
I guess I'd like these five questions answered.
Will this mc work?
What size bore is the mc?
What size is the caliper banjo bolt?
Will I be alright using an m8 banjo on the mc if the caliper uses a larger banjo. Bolt?
Can I just install a banjo bolt Brake switch to activate the brake light with this mc?
Thanks guys!
