measure rpm with voltmeter
Jaydela180
Gurnee, il
Trying to measure acurate 1200 rpm idle
with no tach....
Read a little bout measuring rpm with voltmeter in hertz/ frequency mode.
I understand that reading will show per second and times 60 will get you the rpm, but will that be double actual rpm with our wasted spark?
And can I just measure from coil terminal? If not, where would be ideal to measure from?
Thanks in advance.
Posted via Mobile
Oh, this'll be fun.
Probing on the coil's grounding side will give you a nominal voltage swing of about 12v-14v, but will be higher due to inductive kickback. Depending on your meter's input features (Hi-Z?), may need to put a 1-2 megohm resistor between your probe and the coil's grounding side.
With a wasted spark, you get one pulse per revolution. So, 20Hz would work out to 1200 rpm...
