griennehornette
Two steps forward, and one step back, it would appear.
Just finished re-cleaning the carbs and setting the timing. The Hornette now starts fine, and idles well. But the mechanical advance sounds like the old buzzer doorbell I remember as a kid.
I followed the manual (Clymer) carefully through the stating timing process. It was pretty frustrating; but eventually worked. Used a bent bit of clothes hanger to first keep the advance weights anchored "in" and then use the wire like a spring to push them "out" as per the manual. Well, the manual didn't really specify how to keep the weights "out" and bending the clothes wire to give a bit of pressure and hold them out seemed like a good idea...
Anyway, I've taken the weights off, greased them and put them on again. Still clatter like crazy. I'm pretty sure I did not bend the stops, as I read that's a bad move. So I'm not sure what I've messed up; but the clatter can be heard easily above the engine and exhaust.
I searched the forums, but don't see reference to this phenomenon. Or maybe my search skills leave something to be desired.
Anyhoo. If anyone has run into this before, I'd love to know. Many thanks in advance.
