XS650D
XS650 Junkie
I finally got around to installing used choke side carb body I purchased of EBAY last fall.
To hopefully fix the original unit I never could get to idle /run correctly.Yes we tried everything, something internal was the problem (probably someone screwed the fuel screw in to tight, just a guess, I read this was an issue on the 76/77 38 mil carbs.
The company I purchased from sells rebuilt/refurbed units that are totally gone thru, repainted, new seals hardware ect.The unit looked new to me .It was only the carb body so I proceeded to take everything off my old unit and reinstall. It already came with the throttle shaft, seals and hardware for shaft installed on carb body. I did not
believe there was any need to pull apart. Fast forward, got it on the bike and set up.Good news, was actually able to set the fuel screw to 1.5 turns out and it ran great, no farting ,uneven running ectI used to have my old carb at 3 turns out just to get it to run at all and it still wasn't right! I ended up after balancing the carbs and tweaking the fuel screws both sides are now within 1/4 turn of the stock setting of 1.5 +/- half turn.
Bike is running much better BUT not perfect, still a lil stumbling in the idle.I decided to do a starting fluid test on the carbs and seals.Yep u guessed it, seals not sealing properly, called company that I got carb from just to inquire if they were indeed changed and yes but with aftermarket seals, probably Mikes.I could pull it all apart again and get some Yamaha original units which are available but I decided to try an old trick of swelling the seals with some brake fluid applied to them (I just squirted it on best I could) I did this on an old Chrysler tranny years ago that was slipping (lots a miles) added some brake fluid to tranny. Woked great rite up until I sold it a year later, no more slipping tranny. Has anyone tried something like this on a bike shaft seal.I read that it can swell seal up to 15%.I figure if it docent work then $20 for new Yama seals is worst case sceniro.Just not looking forward to pulling it all apart again! Sorry long winded.
