fcbaker
oldguy69
i bought a junkyard 80 Special and started rebuilding a few months ago. Carbs were a mess but completely disassembled, cleaned and replaced floats, needle and seats, butterfly seals and rejetted to spec recommended for aftermarket exhaust and air filters. I also made all valve adjustments and cam chain adjustments. I replaced the rubber carb manifolds and gaskets. Started the bike and it ran great. Synced the carbs with mercury gauges and took it for a ride. Didn't pushed it too hard because it hadn't run for probably 10 or 15 years. Let the bike sit for a few days and have been fighting a fast idle since. It starts fine and immediately goes up to 3000 rpm. Had the carbs off 5 times and disassembled looking for vacuum leaks. The diaphragms look fine and when I open the throttle both piston raise together. I also installed a new coil, wires, cap and plugs and a Pamco Pete ignition. Lots of sparks and timing is on. Any thoughts or ideas are welcome. I want to replace the stock exhaust but want to get it running right first.
The jetting is now: pilot #45, air #127.5, main #145. Idle mix screws are out 2.5 turns.
