The spigot OD on the VM32 is 40 mm., same as the VM34. Tom, I don't know where you read that equivalence; the usual correction factor for the venturi obstruction caused by the throttle shaft and plate in the BS38 is 2 mm. at WOT; but right, if the aim is a good utility carb rather than high performance, the VM32's should be an excellent choice. XSGLENN, be aware that you'll probably have to swap out every piece of brass in them.
