Mini speedometer backlight wattage
Eotnak
Titusville, NJ
Traditional LEDs use a max of 20ma, but are often configured to use 10ma. So, at 12v, with a current limiting resistor, expect anywhere from 1/8 to 1/4 watt.
Traditional incandescents are 3 watt. At 12v, that's 1/4 amp...
Those gauges look pretty cool. Please send pics and a progress report! :popcorn:
TM,
Can you please explain/describe the current limiting resistor?
Thanks to both of you!
Apparently LED's draw too much current by themselves and can have a short life from current/voltage spikes or something. Whenever I see a circuit there is always a resistor with an LED.
I found this article but it doesn't help me with some of my LED's that I wasn't given specs on.
https://www.evilmadscientist.com/2012/resistors-for-leds/
I was assuming I would just pick an amperage and aim for that. 10mA sounds good I guess!
Actually, I think the original bulbs were rated at 3.4 watts, not that it would make much difference.
