Guss80special
Hi. So I’m trying to wire up the mini tach and speedo I got from xs650direct. I bought matching terminal connectors so I could easily swap btw the stock gauges whenever I want and not damage my harness. I have a spare harness that I have not used yet, which made it a bit easier to sort out in the house first.
The mini tach has only 2 wires for back lights (red and black) stock has 3 (back lights and high beam indicator)
The mini speedo has 10
2 for blinkers
2 for oil, which I plan to use for the headlight fail indicator
2 for neutral
2 for back light (meter light)
2 for hi beam
It has all the lights from stock pilot box, speedo and tach high beam indicator.
I think I got it mostly figured out thanks to some other great posts, except for the high beam ground wire on the new mini speedo. I have both Haynes and clymer wiring diagrams. Clymer has the black ground for the high beam indicator connecting somehow to the 6 space Pilot box terminal connector block. That is not possible. See pic #3. Haynes is a bit more logical in that it shows blue, black and yellow coming out of the tach and connecting to the harness via 3 spot connector. Haynes also shows the black ground for the high beam indicator light connected to the black meter light wire. Presumably inside the tach housing, hence only 3 wires coming out not 4. At least that’s what I think it’s doing.
So what should I do with the blue/black ground wire on my new speedo (hi beam indicator) ??
I’m thinking I need to splice it to the mini tach meter light black ground wire?
Also. I’m obviously removing the ‘reed’ switch, is there anything I have to consider in that regard?
Thanks for any advice
See pics.
2 for blinkers
2 for neutral
2 for hi beam
See pics.
