walterpunk
well i replaced the shift shaft on my 79 special and buttoned everything back up and attemepted kicking it over but the kicker had a lot of resistance so i took it all apart again and noticed i was scratching the hub pretty good....so i noticed there is no ball in the worm gear and that i only had one washer in between the hub and needle bearing... so what im getting at how do you suggest i put the washers in? the way mikes xs says with the bearing against the hub then the thin washer and then the thick one?? also is the ball i need for the worm gear the same as the clutch pushrod ball?? also when i play with my shift shaft i can only grab 1st and 2nd? did i maybe put it in when the bike was in a higher gear? or do i need to do more than turn the engine to get the higher ones?
