Make Offer - Modded 1982 XS650 w/ Clear Title
Jerm
XS650 Junkie
Indiana
I am looking to sell this bike I put together over the last few years. I am not looking to part it out at this time. If it looks like something you are interested in, send me a PM. I rewired it with the attached diagram using the stock TCI system. Kick and electric start. Tank interior is spotless. Exterior has OK original paint. I would also sell everything and keep the motor and carbs. I have purchased and installed everything below. Nothing listed has more than 500 miles on it:
$3,000
TX750 Swingarm
Bronze Swingarm Bushings
Pivot Shaft
Tapered Steering Bearings
Aluminum Riser Bushings (HHB)
Speedo Delete (HHB)
Front Axel
Trued & Balanced 36 Spoke 19" Front Wheel (Not NOS, but SUPER Clean) w/ Like New Bridgestone Accolade Tire
Trued & Balanced 48 Spoke 16" Special Rear Wheel w/ Like New Shinko Classic 240 Blackwall Tire
Inner Tubes
Rear Axel & Nut
Chain Adjusters
13 3/8" Redwing Shocks from Omar's w/ 60/90 Springs
Mac 2-1 Exhaust
Front Fork Brace (Gordon Scott)
Billet Top Yoke Bolt (MotoLanna)
Upholstered Polished Aluminum Seat & Side Covers
High Output Ignition Coil for TCI
Plug Wires & Caps
Front Master Cylinder
EZ Pull Clutch Cable & Lever from 650Central
Motion Pro Throttle Cable
Non-Vacuum Petcock
Early Style Tank Badges
Engine Turned Aluminum License Plate Holder w/ Cateye Light
Frame Has Been Cleaned up and Repainted
RH Bar Switch form 76-78 bike w/ Headlight On/Off Switch
One Piece Clutch Pushrod
Clutch Pushrod Seal & Bushing
Stainless Steel Upper Brake Line
Front Brake Pads
CRG Hindsight Lane Split Bar End Mirrors w/ Internal Mount Adapters
JBM Intake Manifolds
