When I had my engine apart, I did the standard starter bendix spring squeeze trick, prior the starter had been doing the standard "kick-out" issue associated with the weak spring. Results were ambiguous, at best. But I bought a bike with a kick starter for a reason, so I didn't really worry about it. This year I put a new battery in the bike, and it really woke up the electric starter, but the "kick-out" issue persisted. In addition, now that the starter was getting a good shot of voltage, it was making a horrific noise as it spun down.
So today I pulled the starter, disassembled it, gave it a thorough cleaning inside and out, brushes, commutator, etc. Flushed a lot of dust and grime out of the unit. Then added a wee bit of grease to the bushings(no bearings in there as it is not a continuous duty motor, but the bushings do want some cleaning and lube from time to time). Bench tested the unit and it spins free and silently.
Put it back on the bike, and it feels strong and is much quieter. I have to deal with a broken clutch cushion spring over the winter, and at that time I may replace the starter spring and see if I can't get this thing working properly. At this point that seems to be the only issue.
So, if your electric starter is noisy, or turns slowly, might be worth pulling it off and going through it, you might be surprised at what you have when it's all done.
