From what I've read here , this seems to be a common situation.
This is the 1st one of these motors I've done.
What I have now is :
New chain/ New top end,
The sr500 mod to the cam chain guide (that Jim turned us on to)
Head & rocker box torqued.
Valve adjusters backed off yet,
At first it seemed the 6 holed base plate of the Cam Chain adjuster wouldn't seat.. the chain is so tight.
but, after backing out the adjuster nearly out it seated and I stuck the 6 bolts in.
I rolled the crank nut round by hand a few times with no binding and yet I'm wondering if I should be investigating further or if this sounds typical to you gents.
The acorn cap on will only screw on leaving roughly .080" space before seating,
(hand tight). Will this chain loosen enough after it runs for a few minutes?
Any thoughts appreciated
