My Forks were Forked Up
AussieHard
AussieHardTail
Melbourne, Australia
What some PO do to our bikes before we get it, can be scary!:banghead:
Was servicing my forks on the week end after figuring out I have 76 model fork lowers with tabs ground off to look like 78, on a 74Tx bike!
The left fork was completely dry, and the right only a tiny bit of oil…….:doh:
So rebuilt the forks new seals etc, and fitted it all back up and the damn fork cap was leaking oil…… Put a another fork cap in from another bike same thing……….
Take a look and the PO was drilled down through the threads in two places..:wtf:
Guessing he couldn't get the cap off, maybe he didn't loosen the triple clamping bolts???
As you can see there were two nice big grooves cut in the forks.
I used this rag soaked in a little petrol to clean he oil off the top rim then stuffed the rag into the top of the fork to catch any debris. I moulded some epoxy metal putty into the grooves and let it harden. I then wrapped the fork cap thread in teflon tape to build it up a bit. Once hard I got some emery and sanded the putty smooth. Screwed the cap in down to the O-ring added some silicon, screwed it shut and left it to set.
36hrs later bounced on the forks and no weeping! Yeah baby!:thumbsup:
The rest of the process, and the shed made tools can be found on my blog
http://theflyingxs.blogspot.com/
Just makes me wonder what else I will find:yikes:
