yamahammer
Hey folks, I'm a new guy.
My 76 650 is rephased with Hugh's crank/cam, Mikes 750 kit sans base gasket, modified points with TFI modules/coils, BS38 carbs with pods (25 pilot, stock needles-middle clip, 130 main), classic hooker 2-1 exhaust.
All of the above parts were assembled by me, and I've got it tuned to the best of my abilities. The problem is that it's slow, and it vibrates worse than a 360 above 4 grand. Below that, it hardly vibrates at all.
The clutch doesn't even slip, it can't be putting out what it's capable of. The timing is spot on, the carbs are bench synched and dead cylinder sychronized at idle. Why won't this sucker rev out?
My gut's telling me that the cam isn't appropriate for the increase in displacement and static compression. Maybe I need a cam that bleeds off a little compression, lowering the dynamic compression ration and letting waves fill/evacuate the cylinders?
Thanks for any suggestions, I've bounced this off of all my local sounding boards.
