laramore86
Hey all this is a great forum. I've learned a lot just lurking around. I have a 81 xs650. I bought it few months ago. The PO says the top end has been gone thru 2 years ago and after that it didn't get much action. It wasn't running when I bought it. Dead battery. Put fresh battery in it and started first kick and ran kinda rough. I drained the tank, cleaned the carbs, and got them synced and it ran a lot better. The problem is the left cylinder is burning oil and fouls plugs after 15 miles or so. It smokes as well out of the left pipe but not a big fog just kinda a trailing haze. I did compression test and both cylinders are dead even at 160psi and neither bleed off. I'm at a loss to why its burning oil and smoking. The left pipe is slimy on the inside as well. Any help would be greatly appreciated. The only other info in have about it is that it has a banshee ignition system, no electric start. I've put about a gallon of oil thru it with less than 100 miles. Its burning it. no leaks anywhere until today. The clutch rod seal started weeping.
