luckynumber0
In Over His Head
Hi all,
So the previous owner obviously overtightened the heck out of this bolt (which applies pressure via spring to the neutral detent assembly, as I understand it) and busted the engine casing. You can see in the photos how big a chunk's been taken out...My question is what to do and how best to do it? The bolt actually screws in just a couple threads on the case, as you can see in some of the photos, though I obviously haven't tried to run it with the bolt in.
So far I've considered using HTS2000 on it but I only have a propane torch which doesn't seem to get hot enough...and I don't have any experience with anything hotter. If I could tack it up with HTS it'd be perfect because it only adheres to aluminum so by just tacking it on with the steel bolt in i'd just have to unscrew the bolt to tap the new weld for thread. Has anyone used HTS2000 before? What are my other options? Could i just tighten it up and JB weld it? I'd be happy with something impermanent so long as it kept the bolt from flying out on the highway. Any advice would help!
Thanks in advance!
Thanks in advance!
