ontherocks
- Messages
- 106
- Reaction score
- 3
- Points
- 18
Hello all,
I have been tuning my bike by observing the color on my spark plugs, using info from strappe.com and other sites. However, alot of spark plug pics are black and white or the same pics from the 70's with bad detail.
I am posting pics of my plugs and perhaps some of you can give me hand with your observations and expertise.
I have a slight stumble in upper 4th and 5th gears when rolling on the throttle. Drives me crazy. I can back off the throttle just a hair when it happens and it will go away. Or I can power through the stumble and acceleration picks right up after a few seconds.
I just can't seem to tune out this little bit of hesitation.
Here are the specs on what I have:
1.Bike: Bobber with 1975 motor
2.Carbs: 78-79
3.New Accel 140403 coil. 3.3ohms primary. 21k ohm secondary including the 5k caps.
4.Pamco ignition
5.140 main/ 30 pilot.
6.stock exhaust headers cut off right under the m in yamaha on the right side cover. 2 ft of 2 inch pipe welded on with 4 inch baffles. no leaks.
7. Cam chain adjusted to within 1mm in and out when running
8. Valve lash adjusted cold. .002 intake and .004 exhaust per chilton manual.
9. Timing set dead nuts on the timing mark with timing light.
10. Mikes xs performace pod filters.
11. Dead Cylinder method performed seeking highest idle. left mix screw at 2 1/4 turns. right screw at 3 turns.
12. synced using manometer before and after dead cylinder method.
Just trying to give you complete information to go by before diagnosing.
Her are my plug pics for your viewing pleasure.
And yes, ipad2 camera is less than stellar.
2.Carbs: 78-79
4.Pamco ignition
