PatDoody
This is a project bike I took over. Ive had it for about a year but only heard the motor run for the first time a week ago. Ive yet to ride it because the clutch will not engage. If I mash the thing into a gear and pull the clutch I cant move the bike. Then I have to try to find neutral again to move it. Ive put a new cable on adjusted the worm gear. Tried the old cable. Adjusted the worm gear.
I pulled the right cover off today. The clutch is moving . Today I tried the trick to drill another hole in the worm gear lever arm to get more throw. It seemed to work as far as more throw, but didnt fix my problem.
I havent pulled the clutch pack off yet, I can see the levers moving behind the clutch pack when attempting to find a gear. Is there something I am missing that I should check that might be seized.
I also tried the trick of pulling that 7/8's cap off and stretching the spring. Is the spring supposed to have a hole to go down into? What ever that is the spring pushes against is about flush with the top of the case and doesn't appear to move.
