Eotnak
1982 XS-J Heritage Special
All stock. My research (thank you for this site, guys!) tells me to go about reconditioning this bike in a certain order. I've already taken care of the cam chain tension and valve lash, when I went on to *check* the timing, I decided to test the coil. Following Clymer's, I found the coil to be just barely out of spec. I can't recall what I did other than remove the coil and put it back, but now the bike doesn't start at all, and now the coil is WAY WAY out of spec. 3.5 ohms across the primary coil, and 1200 ohms across the secondary. I just want to get it running right, and I'm on a strict budget. Does this sound like doctor's orders?
https://www.mikesxs.net/product/17-6803.html
also, it says to mount it backwards, so I assume that means new longer wires:
https://www.mikesxs.net/product/23-2902.html
those are "high tension wires" like the coil's description states. Which I assume just means "spark plug wires". Is there any advantage to using the yellow ones that justifies the extra $3?
https://www.mikesxs.net/product/23-2906.html
thanks in advance. I'm probably overthinking it, but this is my first bike and I'd like to get one thing right on the first try for once in my life.
