txpowdercoater
- Messages
- 206
- Reaction score
- 2
- Points
- 16
ok, I am doing the wiring harness from scratch, its pretty easy stuff.
The only issue is wiring the neutral switch to turn the headlight on.
I have done the search and read every thread and wired as supposed to, but it only comes on in neutral and not in gear.
I would rather use the neutral switch and relay if possible instead of a headlight toggle.
heres what I did :
on relay pins
#30 and #85 to 12v.
#87A to headlight wire
#86 to neutral switch
that combo didnt work in gear, only in neutral, so I did the following:
on relay pins
#86 and #30 to 12v.
#87 to headlight
#85 to neutral switch
still only works in neutral, even w/ headlight on #87A
ideas, comments good bad or indifferent welcomed
heres what I did :
on relay pins
#30 and #85 to 12v.
on relay pins
#86 and #30 to 12v.
#87 to headlight
