82heritage
Hello,
Just picked up an 82 xs650 looks to be all original with 9k miles. Needs to be cleaned up and I am not so sure about the motor. The PO drove it to my house so it runs but the left side exhaust was throwing out some darkish smoke when revved up. I am going to change the oil clean the filters and all that. After that I want to clean the carb and possibly rebuild or have someone rebuild as I have never worked on one before.
Questions as I could not find these using search.
My starter engages but makes whirring and unhappy noises. All the reading I've done points to the #4 gear on the right side of the engine and the tension like clip that seems to wear out. Is this a pretty cut and dry job or does the clutch need to come out ?
Other question, Until I work that out I do not want to do any more damage and will try and kick start her.
What is the right method for doing this as I could not find a guide. Choke all the way and kick away or should I be giving it a little gas?
Also, on an 82 what position do I leave the petcock valve on when I am not running it until I replace it with a manual one ?
Thanks again,
Mike
Thanks again,
Mike
