tonyc
XS650 Guru
I wish I had your mechanical talent.
Posted via Mobile
Posted via Mobile
Isnt 6061 aluminum aircraft grade? I have only seen that here in flat stock mainly.
The steering range on the Buells is pretty tough in tight places. I only notice it when I'm pushing it around in the garage or if I'm trying to pull a really tight U-turn in a parking lot. Your idea looks good though, if you ever decide you need more movement you could just grind down the stop on the head tube so it's a little skinnier. Wish the buell triples came with fork stops already on them. I hate how a little piece of foam-rubber glued to the frame was their best idea for a fork stop. Not sure if your x1 is the same way but if you had an M2 then you definitely know what I'm talking about. I'd say for brakes, since you already have the mill, the easiest option would be to make a brake caliper adapter(or two) so you could just run the normal xs rotor and caliper(or two). You could also just make an adapter for the buell rotor to keep the nissin caliper if you though the xs parts would look a little scrawny on the new bigger forks and didn't want to clutter things visually with a caliper adapter. Either way would look good!
Good call on the bolt instead of the retaining clip. Not sure which handlebar clamp you have for those forks. If you want something a little cleaner than the bulky clamps they typically have, when I had my XB I bought a spare handlebar top clamp and cut it down so it was just the two individual clamp halves and removed that whole center part. I thought it looked a bit nicer than the original part. I'm sure you'll come up with something good though. I can find a picture somewhere if you're not sure what I mean.
I've seen some nice X1s. I agree I like the minimal look of the S1(and the XBS), I always thought the X1 looked a bit busier, with the bigger tail and larger tank. I'm sure the FI is nice, but mine runs well with the carb. I just picked it up in February, met the owner halfway to pick it up(Pittsburgh to North Caronlina). Needed fork seals, new front brakes, and turn signals before it was ride-able. Unfortunately that took 6 months due to a kitchen redo that consumed all of my time. I just got it on the road about 2 weeks ago but it's been great since! ....aside from a dying sidestand switch that occasionally kills the engine and makes it look like I have no idea how to pull away from a stop sign haha.
