Pinging or pre-ignition due to the timing being too far advanced (worn advance) literally blows through or explodes through the piston top a little at a time. I think it would or could look like that.
This top end gasket kit SCM-XS2T listing has ended, but this kit SCM-XS1T would likely be the same. Others will chime in on that I'm sure, so wait for confirmation before you pull the trigger on that.
Unfortunately the only source we now have for the front and rear cam chain guide and tensioner assembly is MikesXS.
The head gasket in that XS1 gasket set won't fit properly on the later 447 heads/cylinders. The mating surface area between them is larger on the 447 motor, smaller (narrower) on the XS1. I wouldn't recommend that gasket set unless you had an XS1.
Yes, I bought 3 or 4 of them over the last few years, for future use. Cripes, a head gasket alone costs more than that whole set was selling for, lol. Granted, it didn't include valve guide seals, but that allowed you to get and use those Viton ones from eBay. And on the "plus" side, the head gasket matched the thickness of the original.
Welcome Harpo57. I posted a note in another thread a few minutes back where you had shown a photo of your pistons. I then discovered this thread of yours so deleted my comment. I asked if the hole was melted or was it a crunch due to a foreign object getting into the cylinder? The edges of the hole just seem too sharp/thick for melting. Also, did you clean the top of the piston or did it self-clean due to overheating? I pointed out the issue with the guide but I see this has already been thrashed out.
