Seeing the brass washers on the 4 outer head bolts would suggest it wasn't just thrown back together without thought.
Nice ride and 750 to boot!
No. This project started a bit late in the day. My goal was to quickly clarify whether or not we were dealing with mayor issues. Once we got it back together, it went off the lift, kick started, and test driven. It was time to put it back on the trailer. We got a lot sorted out, but there's plenty still on the table. He did go home with a running bike. Timing is suspect as kick starting this bike isn't easy.Did you guys actually do a timing check with a timing light, and if so, is it advanced a little?
Well, that TCI sensor looks a tad advanced to me too... still has the original screws, so that seems odd... but anything's possible I guess.
I run the TCI about 35-37°. Seems to run a tad smoother and no change in engine feel as far as power. And that would definitely help starting it.
Yes, they used screws that sheared off the (driving) head when it was torqued. Tamper proof....Are the pickup coil fasteners factory for a 1980 stator?
Question, when using this filter, does jetting change from stock?Did you guys actually do a timing check with a timing light, and if so, is it advanced a little?
The best pod filter to use is the straight foam UNI. For your BS38 carbs, you'll want the UP4200 or UP4200ST (dual layer) ......
Pictured above is the UP4200. The dual layer ST version is nothing more than this same filter with a red foam "sock" slipped over it. Remove it and you're left with the plain 4200 as seen above. You don't need the dual layer ST, and it costs a few dollars more. For oil, don't use the special foam filter oil they make, it's too thick and can clog the filter. Instead, just use a simple 50-50 mix of motor oil and gas. I bought a bottle of cheap Walmart brand straight 30wt. to use specifically for this ......
Yes, even though they're not needed, I do have the dual layer ST filters on my BS34 equipped '83. The only reason I have them is because I got them cheap from a local guy who bought them for his bobber and they wouldn't fit.
Depends.Question, when using this filter, does jetting change from stock?
Probably. When I went from OE mouse fur filters to K&N, jetting changed.Question, when using this filter, does jetting change from stock?
We need to put a test light on that thing. Do you have one? Disconnect the ground cable from the battery. Key off and out. Place the test light one end on ground and the other on the negative battery terminal. Any glow means there is a drain on the battery when it’s sleeping. I’m afraid I’m out of pocket until after Thanksgiving, but eager to have another go after that or first thing 2024.Update on the bike. I purchased the UNI air filters and installed them. The bike was on a float charger for several days. The starter did not want to turn the bike over. Not a real surprise considering I have not ridden the bike in days. I went to kick on it and it turned over no problem. Nice and smooth. The bike did not try and kick me back. I took it for a quick 15 minute ride. The bike ran great. No issues. I also checked to see if the headlight would brighten when I revved the motor and it did as well. So I assumed the bike was charging correctly. When I got home I turned the bike off and left it for 2 to 3 hours. Key was out of the ignition. When I went to start it again the stater gave me one weak little attempt and died. I could not kick the bike over either. I put it back on the float charger for 20 minutes. I came back to the bike, kicked it once and it immediately started. I tested the voltage at the battery and it read 9.00. I revved the motor and it went up to 9.30. That was as high as it would go. I put it back on the charger overnight. Battery read 13.35 in the morning. Could something be draining the battery with the ignition key out? Could the charging system be charging the bike but not enough to sustain the system? I checked the rotor again and it read 5.2-5.5. I tested the battery 6 months ago and it was good. Could the battery be bad now from all my issues? When Marty and myself were working on the bike he mentioned that the head light is not factory. Could the aftermarket headlight be pulling to much power? Ill attach a few pictures of the headlight. Thanks again for all the feedback.
That would be my guess.Could the battery be bad now...
