pnedac
Thank you in advance for your help. I just am wrapping up my first build by myself and it has been one looong road. I started in February with a rusty barn find and now have a pretty sweet looking bobber. I recently switched the stock carbs out with brand new VM34 carbs. The rubber connectors from the carb to the engine have a nipple on each one that points down that the stock ones did not. What is it for and what needs to happen with it? I suspect that the tube coming out of the upper side of each of the carbs needs to connect to it but I am not sure that is really what it is. I am on the right track?
Also I have pretty much straight pipes with glasspacks and then they turn 45 degrees up and are cut. Could this, or the fact that I do not have any air filters on the VMs when I am trying to get it dialed in be causing it to not idle well? It idles either not at all or very high when I start it. I am so very close with this beast but I am facing these last few hurdles. I also was not exactly sure how the idle adjusts and how the main jet screw works with the upper springed idle adjust. I have read the Mikuni VM manual but it does not really discuss how to get them dialed in. I would have thought that this would be a little easier, especially with all new parts!
77 XS650 bobber.
Pnedac is strugglin' !!!
77 XS650 bobber.
