Punkskalar
Hugh's HandBuilt
Late Model 447 XS650 Engine
Rebuilt and Rephased to 277 Degrees
Will have a NEW 750CC (Gary Hoos JE Pistons and Liners)
Still on the engine stand
5th Gear OD
XS1 Camshaft
Permanent Magnet Alternator Conversion - Hugh's HandBuilt (optional)
Bead Blasted Cases, Cylinders, Head, etc...
3 Angle Valve Grind
Deleted Starter
New Cam Chain
New Cam Guides
All New Stainless hardware
Heavily Ported Head
34MM Lectron High Velocity Carbs ($750 New - Optional)
TC Bros Long Runner Intakes
8 Pack Clutch
1 Piece Clutch Rod
HD Throwout Bearing
All New Seals and Gaskets
Brass Head Washers
Outright - $3750 ready to install as is
Minus Carbs, Intakes and Charging System - $2,900
Offers accepted as well..
5th Gear OD
XS1 Camshaft
3 Angle Valve Grind
Deleted Starter
New Cam Chain
New Cam Guides
Heavily Ported Head
8 Pack Clutch
1 Piece Clutch Rod
HD Throwout Bearing
Brass Head Washers
