So after 175 mile jaunt through the Sierras (1200-6700') last weekend I'm on to the next level of tuning woes.
Bike always starts first kick when warm now, idles nicely, crisp throttle response at very low throttle openings 1/8 turn or less. Above that level of throttle (coinciding with approximately 3000 rpm) there is a frequent "pop" when under power. There is no breathe back through the carbs and no true backfire occurring, nor is there any stumble or poor running at closed throttle or on deceleration. The "pop" is when under power whether cruising or under acceleration at over 1/8 turn of throttle all the way up to full throttle as well as from 3000 rpm to redline, sometimes as low as 2800 rpm.
My plugs are dry with no sooty deposits and made me think of slightly lean conditions for needle (mid throttle openings) and main jets (3/4 - full throttle), while my idle jet is clearly spot on (easy starting, no burble or hesitation or popping on deceleration).
Does that sound right? I just want to make sure I'm thinking about it properly. With all that said I've just switched to stock headers and will be fitting some shorty glass packs later this week, and will see how the pipe change affects the tuning as it sits. The construction of a skid plate has made the MAC 2 into 1 an impossibility.
I've got 138 mains and GJH needles with a single shim. 38 idle jet. UNI foam filters.
I am thinking I may need my 140 mains fitted and to do the nailheads for needle enrichening.
Let me know if I'm missing something, please!
