I want to say its within the first 15 pages of this thread.
I believe try do run better than the bs138 I had. Note that if you have the carb holders for 38s you will need to get ones made fr the bs34. The intake diameters on the cvk are 34mm. I recommend JBM. They are pricey, but very high quality and don't need the metal cages you are used to with bs38. JBM are metal with a rubber outer coating, so they are much more rigid than the stock type. Around $70 per set, but good.
I got my pair used for $80 on eBay, then with assorted jets, needles, intake manifolds, and filters I got mine done for just under $300.
They are set and forget. Idle better than my 38 ever did, much better throttle response. I originally searched for a replacement for bs38 because I hated the cv lag. The cvk reduce that effect by half or better. Not quite an Amal (what I'm used to), but darn good.
