thunderdork
Been debugging the electrical on my 78. i replaced the coils, caps, plugs, boots, wires and points. still nothing. so i went and bought a continuity tester. hook it up with the points and ground it to the neg terminal. turn on the ignition. rotate the rotor a few times. never saw a blink or heard a beep. at this point i'm wondering if its a bad wire somewhere or a bad ignition/kill switch... if that's the case, is there an easy way to jumper the ignition and or kill switch to see? if that's not the case, what should I test next and how?
