The scenario with float valves isn't that they may not be passing fuel, but that they may not be regulating fuel flow, thus causing a rich condition, and fixing the petcocks will not correct that. Trouble can be caused by debris blocking the valves open, poor machining of seats, wear, or low float level setting (=high fuel level). To check if the pods are causing the mixture problem (on VM's they shouldn't, but that they'll pass enough crap to cause premature wear to rings and cylinders), try removing them. The pipes and pods should not be causing a rich condition.
Combustion is a tripod, and its three legs are ignition, compression, and fuel. You won't fix either of the first two through the carbies.
You asked for advice, so I'll give it. Stop looking for the magic bullet. Troubleshoot everything methodically, one step at a time. You've been skipping steps, playing "Yes, but...," and fishing for shortcuts. There aren't any.
