82heritage
Hi guys,
So I dug into replacing my starter gear and have hit a snag.
I replaced the gear and that part went well. The issue was the reassembly. Now when I put the clutch back on the plates aren't tight. They can by moved by hand. I snugged everything down on this side to no avail, does anyone have a blow out diagram of the clutch setup? When I pull the clutch lever now nothing happens on the clutch side, is that a problem or is it because there's no oil in her right now.
Second the kick start lever engages the gears but will not drop down when I go to push on it. I was doing that just to see if I had it in correctly.
Sorry for the dumb questions but this is my first tear down.
Thanks,
Mike
Thanks,
Mike
